cheers mate, I've got a stock car with a few issues...the diagnostic port is one of thembut appreciate knowing where to go and who has parts. long live the forum
Happy to look at your car. We are VW specialists and are based at Campbelltown.
We carry most parts for Mk4s, including the suspension bushes and strut top mounts and are often cheaper then importing from o/s.
We also can diagnose your car correctly which means you only spend money on the right thing.
Jmac is probably right - clunking when going slow over bumps is most likely swaybar links - same symptom in my car turned out to be the the swaybar D links onto the subframe.
You can also see if yout strut topmount bushes have collapsed 'cause it causes a gap to appear between the chassis and the top plate of the suspension in the engine bay.
