Results 1 to 10 of 20
Thread: sunroof question
    Redfern NSW
    sunroof question
    when you open your sunroof, does it open like this:
    or like this:
    mine normally opens the first way unless i play with it a bit. whats the deal?
    Aug 2006
    mine goes all the way in, 2nd picture
    if yours is like the first pic then i think its stuck!
    Redfern NSW
    Quote Originally Posted by 1DUB2C View Post
    ah sweet cheers, yeah when i flick it just goes to the first position. then i have to push the grey cover in myself and then put it to the off position before it will go all the way in...strange.
    Jun 2007
    Hi Fuzz,
    The one on my Jetta opens like the first pic, never tried playing with it to open it all the way, just thought that's how it should be.
    George
    06 Jetta 2.0TFSI Killed by a Lexus!
    09 Eos 2.0TSI DSG Loved this car but has now gone to a new home!!
    14 EOS 2.0 TSI has arrived!
    Sep 2007
    As I understand it, the sunroof has 2 open positions. The first, when you turn it anti-clockwise and stop, is a "best position". If you continue to turn it till the knob stops, is open. Then, you obviously have the tilt option if you turn it clockwise.
    Aug 2007
    newcastle australia
    if i recall on my MK4, not only do you have to flick the switch to the open position, but then twist the switch past the 'open position' for it to go all the way like the second pic
    took me a few months before i figured that one out on the GTI *sheepishly*
    yea what sierra said! (got your post in whilst i was typing)
    Aug 2007
    doncaster, vic
    hahah yeh took me a few months too!
    MK4 GTI|REVO|4BAR ADJ FPR|APR FMIC|APR R1 DV|TURBO INLET PIPE|KONI|WHITELINE|CUSTOM CAI + K&N|2.5" TB + HI FLOW CAT| ECS DOGBONE
    Aug 2007
    Perth, Australia
    yup, it has 2 positions. I had a 1990 Vectra that had the same thing, as well as a 1996 Laguna and a 1991 Soarer. This is my first car without a sunroof!
    1991 BMW 318is RED E30
    Redfern NSW
    i'll have another muk around this arvo because when i go anti clockwise all as far as the switch will go i get the first (not completely open) option. then i have to push the cover in myself and switch it back to the closed position, it will start to close and then retract all the way back in.
    car is at euro automotive today getting a full service.
    oh yeah while i'm writing just a side note, i'm looking at options to stroke out the motor a little more. the '03 GL TDI has a 95.5 mm stroke and the same bore as opposed to the 86.4mm stroke of the GTi. This would increase capacity from 1781 to 1969 and by my calcs would mean increasing the combustion volume from 52.5mm to 58 to retain the 9.5 compression ratio (via the head gasket). Might be an option, has anyone looked at boring or stroking these motors? I'm staring to do the research into this and adding a second larger turbo in a sequential set-up if anyone is interested in these topics. also building a digital tacho which i'm going to put on the dash as a head up display but i'll put that up as a topic later.
    f
    Redfern NSW
    Quote Originally Posted by dub_boi_oi_oi View Post
    this is why i want to get a factory manual!
