Results 1 to 10 of 12
Thread: Sunroof problems
    Sunroof problems
    I'm having problems with my sunroof for a few months now, but as it has been winter I have just left it... But with Spring just around the corner I think its time to try and fix it!
    Does anybody know how I can possibly fix it?
    It wont open, and when it tries to it makes a loud creaking noise and opens a bit and then as a safety measure goes back and closes its self.
    I think it may have come off its rollers perhaps...
    Any ideas...
    Feb 2008
    New Zealand
    have you flipped the emergency cover down and tried manually winding it with eh supplied allen key shapped winding tool?
    wind it back to see where the resistance happens and you may be abel to fish out what ever is blocking it
    - 2010 Golf R
    - 1997 Golf VR6
    - 1989 MKII Golf Diesel
    - 1987 VW Golf GTI 16V
    Oct 2006
    i think theres a repair thingy in here somewhere
    http://forums.vwvortex.com/zerothread?id=1835863
    Quote Originally Posted by HitmanR32 View Post
    By emergency cover you mean the inside of the sunroof that is made of the same material as the interior?
    (The bit not made of see thru glass/plastic!)
    Jun 2008
    Sydney, The Hills
    Quote Originally Posted by hutchjnr- MTM GTi View Post
    No, Not the piece that slides back to reveal the glass of the sunroof, the piece that is between the lights on the front of the roof, and the sunroof itself. There is a small square shaped panel that when you pry your fingers under the front edge, should pop off. On the inside of this cover there should be this 's' shaped allen key tool that Hitman is talking about. Take that out and place it in the centre of the circular part of the sunroof motor (the motor is also under this flap also) if it does open manually, then the tracks should be fine, maybe the gear in the motor has had it, which means that motor needs replacing. However, maybe it just needed to be moved manually as it may have been stuck, so open it manually and close it, then try the knob again...
    Goodluck
    thanks for that boys... I'll have a go prob 2moro and let u know...
    Appreciate the help
    [QUOTE=EVN-88G;198298]the piece that is between the lights on the front of the roof, and the sunroof itself.
    Hey... gee i feel like such an idiot!
    Lights on the front of the roof??! I'm not following...
    Jun 2007
    [QUOTE=hutchjnr- MTM GTi;198874]
    Quote Originally Posted by EVN-88G View Post
    I'm thinking interior lights?
    George
    06 Jetta 2.0TFSI Killed by a Lexus!
    09 Eos 2.0TSI DSG Loved this car but has now gone to a new home!!
    14 EOS 2.0 TSI has arrived!
    ah ok gotcha!
    The bit that looks like it could/should be a sunglass compartment!!?
    Jun 2008
    Sydney, The Hills
    Yer sorry, that was my derranged way of saying the interior lights, towards the fornt of the roof... And yes, it is that compartment that does look somewhat like a sunglasses holder....
