Results 1 to 10 of 16
Thread: sunroof is leaking??!! please help:(
    Aug 2007
    melbourne
    Over the weekend we had a few much needed showers in melbourne, unfortunatelly for me it seems that more of it ended up inside my car than inside the water tank (preffered option). Now for a bit of background i have noticed that after rain, car wash etc. when i open the sunroof there seems to be some water just below the seal at the front of the sunroof, where the plastic frame (? sorry no idea what these things are called) folds into when the roof is fully closed and springs up from when you open it.
    Having spoken to a few people it seems to me that this is normal as the seal is not suppposed to be water tight (or so ive been informed) and that there are some channels that the water should escape from. Upon closer inspection i have noticed what could be channels on both sides of the sunroof, but then again they could be something that is totally irrelevent to my issue..
    Now my question is basically when you guys open your sunroofs is there any water in there and if there is does anyone know where its supposed to go?? And if theres isn't does anyone know where i can get a new seal?? Roof, Roof... sorry that was real stupid..
    thanks
    Check near the door hinges that the drain that is there hasn't been crushed or blocked. You should see a small tube sticking out. This often gets crushed causing water to bank up.
    Quote Originally Posted by Whubbsie View Post
    There is nothing better than a polo badge, thats why you will notice Veyron drivers with polo gti badges.... they know where the true sizzles at!
    Aug 2007
    melbourne
    Quote Originally Posted by 99gti View Post
    ok so there is a drain, so im on the right path. thanks i will check now. BTW that was a lightning fast response, thanks heaps
    Point Cook, Vic
    if you open the sunroof and look there should be drain holes in the corners. get your mechanic to go at them with some compressed air
    Quote Originally Posted by dre211 View Post
    No probs! It's a fairly common prob with Mk4's so I've been told.
    Aug 2007
    melbourne
    hey Neil, I just found a rubbery, spouty looking thing near the hinge and played around with it a bit and WALLA out comes like a fingernails worth of gunk and then about half a litre of dirty water.. Thanks heaps mate, i will be checking that more often now, but as it seems we have found and fixed the problem we probably wont get any rain in melbourne for the next few months.. or maybe at least untill i wash my car next.. sorry farmers..
    You can trim it back a bit to stop it from blocking up.
    No probs - glad I could help!
    Nov 2006
    Does anyone on these forums actually do any work at work??
    Mar 2007
    Newcastle, New south wales
    Quote Originally Posted by SoVeReIgN View Post
    No
    Okay... maybe sometimes
    GTI. Leather.
    tint,Eibach pro-kit,Whiteline adjustable swaybars,Forge s/brace,BMC,Forge T.I.P & D.V, Cupra R, APR. EBC & 3''dump pipe
    I'm working. I have 2 big scripts running on 2 switches. I'm responding to emails and saving the world at the same time. I have a page of new posts on the forum and also anothe page display who's online and what they are up to (watching for spammers).
    The joys of having 4 19"LCD's on your desk!
