![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
h100vw
Not only do they get blocked but the the flexy pipe comes off the stub on the shell and water gets in that way.
Try pouring a small amount of water in each drain and making sure that it winds up on the floor at each corner of the car.
Front ones drain between the door and wing can't remember exactly for the back.
if you look where you change your brake bulbs, down the bottom is where it comes out (outside if the car tho) .. u can feel it if u put ur hand underneath the bar and up a bit. has happened to me, simple case of it being blocked
