Mate call around your local automotive shops like repco and autobarn and ask for an oversize sump plug with a piggyback. This cuts a new thread and seals for life. Then the piggyback is the new drain plug . Ill have a look aroiund but im sure these places do that. otherwise these guys in the states do the lot matehttp://www.cgenterprises.com/drain_plugs_oversize_repair.htm. If you are worried about the swarf take the sump off no dramas and reseal with the proper VW AMV paste. Let me know if you are stuck mate.
Cheers ( by the way if you go the states option you need 14mm oversize piggyback which is 14.5mm and a seal too 2602.)
