Results 1 to 10 of 15
Thread: Sump drain hole stripped
    May 2007
    Jimboomba. QLD
    Hi all,
    HELP!!!!
    While giving the Golf an oil and filter change today, I noticed why I had been having trouble getting the engine sump plug to seal....the thread had stripped out of the drain hole in the sump...BUGGER!!!
    After buying the golf last year (MK4 1.6L), on the first oil change I noticed that the sump plug had lots of sealer around it...I now know why.
    The car came with a full service history but seems to have been serviced by Gorillas.
    1st question - has anyone else had issues with the thread stripping out of the sump drain hole...the sump is cast alloy so I am guessing I am not the first to have this happen.
    2nd question - what did you do about it?
    3rd question - is there a "reputable" workshop in Brisbane who could fix this issue. I am guessing the sump may need to come off to re tap the thread.
    Any help you could give me would be a great start.
    Thanks everyone.
    2010 90TSI Manual / Comfort Pack / United Grey
    RICE - Leave the useless wings to the Penguins...
    Aug 2007
    Mate call around your local automotive shops like repco and autobarn and ask for an oversize sump plug with a piggyback. This cuts a new thread and seals for life. Then the piggyback is the new drain plug . Ill have a look aroiund but im sure these places do that. otherwise these guys in the states do the lot matehttp://www.cgenterprises.com/drain_plugs_oversize_repair.htm. If you are worried about the swarf take the sump off no dramas and reseal with the proper VW AMV paste. Let me know if you are stuck mate.
    Cheers ( by the way if you go the states option you need 14mm oversize piggyback which is 14.5mm and a seal too 2602.)
    Alba European
    May 2007
    Jimboomba. QLD
    Sump plug
    Hi Jimmymac,
    Thanks for the info, I'll look around at the auto stores.
    In your opinion, do I need to remove the sump? I just have horrible thoughts of swarf, bearings, seals all mashing together....
    Thanks
    Jul 2005
    Sump thrad
    Very common problem,try and find a wheel bolt from a 1500 or S bug.The thread is a little bit bigger in diameter and the bolt is longer and will pick up the unstriped thread.You don't even need a washer as the taper on the wheel bolt seals well.
    Widebody Cayman S Turbo, 83 ur Quattro
    2000 996 C4 cab,12 Scirocco R OEM+ STG2+
    72 914 (3.2S boxster pwr), 92 G60 Corrado
    76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
    Aug 2007
    There would be minimal thread when you fit an oversize one as it cuts its own. IMO if it were mine i would fit the oversize and then take it off to clean. Easy sump mate. then the mind will be clear.
    Cheers. Try and get a piggy back mate then there is no fear of alloy damage later. The piggyback plug will be your new plug.
    Alba European
    May 2007
    Jimboomba. QLD
    Sump plug
    Hi all,
    Thanks for the info everyone. I think I might do the piggyback idea. Just to put my mind at ease.
    Are the sumps "leakers" ie. is it difficult to get a good seal again? My last car had a pressed metal sump and it leaked and leaked I guess that being cast, it would be easier to get a seal again.
    Any tricks before I start?
    What size piggyback should I be getting given that the original thread looks about 14mm?
    thanks again
    Aug 2007
    Yeah you are right it is 14mm, you need a 14.5 oversize sump plug with a rubber impregnated seal. Look up this site http://www.cgenterprises.com/drain_p...ize_repair.htm
    This will give you an idea
    Jimmy
    Alba European
    Aug 2007
    Repco can order one for you at around $22 , piggyback, they didnt even know about such a thing surprise surprise.
    Alba European
    May 2007
    Jimboomba. QLD
    Piggyback plug
    Hi,
    I rang around today and got the same response..."you want a what?".....
    However....my local Autopro shop in Jimboomba has ordered me an oversize piggyback plug, will be here Tuesday or Wednesday..how much..."about 6 bucks" was his reply.
    I rang VW (Springwood) regarding the sealer for the sump.....No one had any spare mind bullets there today either..."just use some silastic" was the reply from the parts guy...I think not. I have some Loctite 510 gasket replacement that maybe ok to use but will do a bit of research first.
    From the responses you would have sworn that I had the first stripped sump drain hole in the history of the automobile.
    Thanks Jimmymac for pointing me in the right direction.
    May 2006
    Maryborough Vic
    Talking
    I've seen a few on other model cars
    seen many late model holdens that have been heli coiled
    you won't need to take sump off
    even if you cut a new over size thread and fitted heli coil
    a heli coil is stainless steel thread looks like a spring
    you just tap a new thread screw in heli coil with loctite
    and you can use an original sump plug
    even done this to fix buggered spark plug threads without pulling head off
    most reputable mechanics could do it and prob have done it
    that if the over size one doesn't work of course
    you should be fine though
    hope your leak free soon
