Need some help.
Ive got a Vw Mk1 Golf with a 2001 Vw Bora (ARX) engine. I hit the sump pretty hard and cracked it.
The code AHZ is stamped on the sump.
What code sumps will fit on the ARX engine?
Need some help.
Less than $300 new from VW.
I did the same with my Rocco 20VT conversion, so welded an oil return fitting into the back of a standard 8v sump and used that.
Dent resistant![]()
Cheers Matt
I knew you would have the answer !!!!!
Can you give me the part number or code for the sump to fit the ARX engine. I rang VW and they reckon the VIN number is wrong and cant help without the right Vin number. Surely it cant be that hard to match a sump with an engine????????
There is a part number on the sump, next to the oil sensor, or on the plate where the sensor would be.
I would just ring VW with that part number and say its for a Golf, no 20VT Boras in this country. They dont need a VIN, its just easier for them.
R o g e r ! ! !
