Results 1 to 6 of 6
Thread: Which sump on ARX (1.8 20v turbo) engine?
    Mar 2010
    Geelong
    Need some help.
    Ive got a Vw Mk1 Golf with a 2001 Vw Bora (ARX) engine. I hit the sump pretty hard and cracked it.
    The code AHZ is stamped on the sump.
    What code sumps will fit on the ARX engine?
    Camden, Sydney
    Less than $300 new from VW.
    I did the same with my Rocco 20VT conversion, so welded an oil return fitting into the back of a standard 8v sump and used that.
    Dent resistant
    Mar 2010
    Geelong
    Cheers Matt
    I knew you would have the answer !!!!!
    Mar 2010
    Geelong
    Can you give me the part number or code for the sump to fit the ARX engine. I rang VW and they reckon the VIN number is wrong and cant help without the right Vin number. Surely it cant be that hard to match a sump with an engine????????
    Camden, Sydney
    There is a part number on the sump, next to the oil sensor, or on the plate where the sensor would be.
    I would just ring VW with that part number and say its for a Golf, no 20VT Boras in this country. They dont need a VIN, its just easier for them.
    Mar 2010
    Geelong
    R o g e r ! ! !
