Page 7 of 8 FirstFirst ... 5678 LastLast
Results 61 to 70 of 71
Thread: sudden loss of boost?
  1. #61
    Quote Originally Posted by Anth1223331 View Post
    I can try and do a log haha don't really know what I'm doing though. I know how to log on the program but do I just WOT from low revs in 3rd or something? If someone could fill me in on what to do that would be great.
    I'm sure it was orientated properly so that wouldn't be the problem. I'm getting the wiring professionally done soon with a new plug as at the moment it's soldered quite poorly as they were cut when I bought the car. But when I was talking to an electrician I know, he said it would still work and shouldn't be a problem but it's just not strong kind of thing. This should be done within the next two weeks and I can rule out/find my problem.
    Thanks everyone for the responses.
    If the N75 wiring is dodgy, you could go to Output Tests in VCDS and click through until the N75 is clicking. Make sure it is. Once you have that clicking, play with the wires and make sure you can't stop it working.
  2. #62
    Apr 2015
    Wollongong
    Ah okay thanks heaps, ill borrow the cable again for the weekend and see how it goes
  3. #63
    Apr 2015
    Wollongong
    I changed my oil today... In the old oil i found little hard brown chunks that were curved like they were part of something. I could easily snap them in half with my fingers and they felt like brittle plastic. The car sounds and drives like its running fine though so idk what or where it came from or if that would have anything to do with my boosting problem
  4. #64
    Pictures paint a thousand words.
  5. #65
    Apr 2015
    Wollongong
    Not sure if that will work but yeah, got these out of the drain pan after i had finished draining the oil. I had cleaned it before hand so it couldn't have been from somewhere else. I also used oil flush so idk if this was just caked on **** that it got rid of.
    Attached Thumbnails Attached Thumbnails sudden loss of boost?-dsc_0048-jpg
  6. #66
    A couple of obvious choices, bits of broken dipstick holder that have been in there a while. Or worse pieces of cam chain tensioner pads.
    Have a look at the dipstick holder with a torch first.
    Either way they shouldn't make it around the engine any further IMO
  7. #67
    Apr 2015
    Wollongong
    Well i just checked out the dipstick holder and it all looks intact with no damage so I don't think its that. Would i notice/hear anything if it was the cam chain tensioner pads?
    Thanks heaps
  8. #68
    Easiest to check the cam chain tensioner by whipping the cam cover off. Not that likely to hear anything depending on what's happened. Dipstick holder may have been replaced so would look ok.
  9. #69
    Jul 2007
    Brissy
    Could be one of the orange plastic pieces on the dipstick, it think they are guides or something. These can come off too.
    I'd like to think it would be safe enough as those pieces look too big to be picked up by the oil pump and would just stay in the sump, and if they are from the dipstick or the tube then they went directly to the sump and did not travel past all the expensive bits.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
  10. #70
    Apr 2015
    Wollongong
    Yeah I checked the actual dipstick and that's all intact and fine. And also I checked out that new n75 I bought and turns out its actually broken and when open, it doesn't shut the third nipple thing so I'm trying to get a refund/return. I've got the vag-com cable now and the wiring and plug to the n75 have been fitted professionaly so I'll do a maf log and post it up here. I'll take the valve cover over and give that a look at within the next week or two as I'm pretty bust atm with hsc trials. Thanks everyone again
