Okay....
So if I cap off the throttle body hose before the inlet manifold I can build pressure back to the tip
I will go through the manual again and have a play
I think its best if I end testing at the inlet manifold as at least if that doesn't leak I can isolate the area a bit more and its more likely in the pcv area
Or not haha....
- You may not post replies
- You may not edit your posts
Forum Rules
