Yeah I've had to replace the vacuum line to the fuel pressure regulator and the one onto the dv. I've done the pcv delete and have a catch can so I cant be loosing anything through there. Maybe your dv isn't holding pressure and Is leaking? I've got the 007p with the weakest spring, green I think, and one shim. If anyone had any suggestions about that that would be great too.
- You may not post replies
- You may not edit your posts
Forum Rules
