I changed my oil today... In the old oil i found little hard brown chunks that were curved like they were part of something. I could easily snap them in half with my fingers and they felt like brittle plastic. The car sounds and drives like its running fine though so idk what or where it came from or if that would have anything to do with my boosting problem![]()
Not sure if that will work but yeah, got these out of the drain pan after i had finished draining the oil. I had cleaned it before hand so it couldn't have been from somewhere else. I also used oil flush so idk if this was just caked on **** that it got rid of.
A couple of obvious choices, bits of broken dipstick holder that have been in there a while. Or worse pieces of cam chain tensioner pads.
Have a look at the dipstick holder with a torch first.
Either way they shouldn't make it around the engine any further IMO
Easiest to check the cam chain tensioner by whipping the cam cover off. Not that likely to hear anything depending on what's happened. Dipstick holder may have been replaced so would look ok.
Could be one of the orange plastic pieces on the dipstick, it think they are guides or something. These can come off too.
I'd like to think it would be safe enough as those pieces look too big to be picked up by the oil pump and would just stay in the sump, and if they are from the dipstick or the tube then they went directly to the sump and did not travel past all the expensive bits.
MK4 GTI - Sold
MK5 Jetta Turbo - Sold
Yeah I checked the actual dipstick and that's all intact and fine. And also I checked out that new n75 I bought and turns out its actually broken and when open, it doesn't shut the third nipple thing so I'm trying to get a refund/return. I've got the vag-com cable now and the wiring and plug to the n75 have been fitted professionaly so I'll do a maf log and post it up here. I'll take the valve cover over and give that a look at within the next week or two as I'm pretty bust atm with hsc trials. Thanks everyone again
