Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 71
Thread: sudden loss of boost?
Anth1223331 sudden loss of boost? 29-05-2015, 04:04 PM
elcono Same here. Be interesting to... 29-05-2015, 07:29 PM
Anth1223331 Yeah I've had to replace the... 29-05-2015, 07:46 PM
Anth1223331 Just a quick little update,... 30-05-2015, 09:22 PM
h100vw When the N75 isn't working,... 30-05-2015, 09:30 PM
Anth1223331 Okay thanks heaps I'll try it... 30-05-2015, 10:07 PM
h100vw Just get the original. I have... 30-05-2015, 10:15 PM
Anth1223331 I still have the stock valve... 30-05-2015, 10:25 PM
Anth1223331 I was just searching the net... 31-05-2015, 09:07 AM
Anth1223331 Wow... Okay that was kinda... 31-05-2015, 10:19 AM
h100vw That's just a test, I can... 31-05-2015, 11:22 AM
Anth1223331 Yeah i took the clamp off... 31-05-2015, 11:51 AM
h100vw google how an actuator works.... 31-05-2015, 12:18 PM
Anth1223331 Well yeah I measured about... 31-05-2015, 12:43 PM
elcono Spooky...... I also went... 31-05-2015, 04:42 PM
Anth1223331 Did you take out the hockey... 31-05-2015, 04:48 PM
elcono No sir I did not..... Read... 31-05-2015, 05:08 PM
Anth1223331 haha yeah i was doing it for... 31-05-2015, 05:16 PM
elcono Haha So you cap off the... 31-05-2015, 07:07 PM
Anth1223331 Nah you can just cap off the... 31-05-2015, 07:56 PM
elcono Well, I used a bit more epoxy... 01-06-2015, 09:08 PM
h100vw Where are you blocking off... 01-06-2015, 09:21 PM
elcono Okay.... So if I cap off... 01-06-2015, 09:53 PM
h100vw Yeah, definitely split the... 01-06-2015, 10:00 PM
Anth1223331 Well my engine must have been... 02-06-2015, 04:25 PM
h100vw Sorry I have never measured... 02-06-2015, 07:22 PM
Anth1223331 Oh okay, yeah with the engine... 02-06-2015, 07:32 PM
h100vw Another consideration is the... 02-06-2015, 07:41 PM
elcono Thought you 2 might want a... 02-06-2015, 07:55 PM
Anth1223331 Hahahah A+ for effort X'D... 02-06-2015, 08:20 PM
h100vw Without a doubt, it's the... 02-06-2015, 09:49 PM
elcono Cant wait to get mine. Should... 02-06-2015, 10:30 PM
Anth1223331 Is it the Ross-tech software... 03-06-2015, 08:15 AM
h100vw The software is free, it's... 03-06-2015, 08:38 AM
Anth1223331 Okay so i would just need to... 03-06-2015, 09:07 AM
Anth1223331 Well if yous think its the... 04-06-2015, 03:32 PM
h100vw My polo has a bit over 3... 04-06-2015, 03:45 PM
Anth1223331 Ah okay. Thanks heaps ill try... 04-06-2015, 03:52 PM
Anth1223331 Okay well i just used the car... 04-06-2015, 04:17 PM
h100vw What about the airflow... 04-06-2015, 06:15 PM
Anth1223331 Well just tried it then,... 04-06-2015, 07:19 PM
Anth1223331 I was searching the internet... 05-06-2015, 11:34 PM
h100vw If wastegate adjustment has... 06-06-2015, 10:41 AM
Anth1223331 Okay, well today i had a bit... 13-06-2015, 12:29 PM
blackers10 check your PCV hoses Anth,... 13-06-2015, 05:26 PM
Anth1223331 Thanks for the input but ive... 13-06-2015, 05:36 PM
blackers10 its not dropping boost... 13-06-2015, 05:49 PM
Anth1223331 Correct me if I'm wrong but... 13-06-2015, 05:58 PM
Anth1223331 Correction: it wasn't the n75... 14-06-2015, 09:37 AM
Anth1223331 Okay I brought the car into... 29-06-2015, 01:36 PM
h100vw You can't log boost on a MK4... 29-06-2015, 02:31 PM
Anth1223331 Ah okay. Yeah its a genuine... 29-06-2015, 02:41 PM
Anth1223331 Well... Ordered a new OEM n75... 10-07-2015, 05:43 PM
theBRUCEofWAYNE I had the same experience.... 11-07-2015, 06:14 PM
Anth1223331 Yeah such a waste of money... 12-07-2015, 11:45 AM
h100vw https://www.google.com/search?... 12-07-2015, 02:58 PM
Anth1223331 Yeah thats how I had it... 13-07-2015, 09:27 AM
schwartza3 hey mate, you should get this... 13-07-2015, 11:56 AM
Anth1223331 I can try and do a log haha... 14-07-2015, 08:41 PM
h100vw If the N75 wiring is dodgy,... 14-07-2015, 08:58 PM
Anth1223331 Ah okay thanks heaps, ill... 15-07-2015, 09:37 AM
theBRUCEofWAYNE sudden loss of boost? 13-07-2015, 07:23 PM
Anth1223331 I changed my oil today... In... 18-07-2015, 05:54 PM
h100vw Pictures paint a thousand... 18-07-2015, 07:03 PM
Anth1223331 http://www.vwwatercooled.com.a... 19-07-2015, 10:29 AM
h100vw A couple of obvious choices,... 19-07-2015, 10:37 AM
Anth1223331 Well i just checked out the... 19-07-2015, 11:17 AM
h100vw Easiest to check the cam... 19-07-2015, 11:33 AM
JustCruisn Could be one of the orange... 19-07-2015, 12:05 PM
Anth1223331 Yeah I checked the actual... 19-07-2015, 02:10 PM
Anth1223331 http://www.vwwatercooled.com.a... 21-07-2015, 08:34 PM
    Quote Originally Posted by Anth1223331 View Post
    Wow... Okay that was kinda amazing. Just clamped off the line to the actuator and went for a drive... What an improvement like holy ****. I think I got to about 17 psi but I wasn't gunning it fully just incase something blows up.. Hehe. So why don't people just clamp it and rejoice in all that untapped boost? I'm guessing it's dangerous and unhealthy for the turbo? Thanks Gavin for the help, probably be looking for a new n75 now then haha
    That's just a test, I can promise a sad face if you leave it like that. Before buying another N75 you need to work out if its the valve or the wiring.
    Apr 2015
    Wollongong
    Yeah i took the clamp off straight after i finished my little test run. I had a look at the wiring and it seems okay, my soldering isn't the best but it all appears connected and i wrapped them in electrical tape so it shouldn't short. So just for my knowledge, what did clamping that line do? Pretty much just stop the ecu from controlling the actuator and letting the turbo run as hard as it can? Will buying a new n75 just bring it back up to approx 10-12psi? Sorry if im being a nub, still new to this
    Edit: I stated the engine and let it idle and tested the n75 plug with a multi meter and got like 7.6 volts. Is this okay or is it off?
    google how an actuator works. Always better if you see it yourself first hand. Don't buy the N75 first. You need to check the wiring. Possibly with the ignition on, you will see voltage across the N75 plug. Never had to check this with a meter as I can use VCDS to do an output test of the N75 which makes it click once a second. Proving it works.
    Apr 2015
    Wollongong
    Well yeah I measured about 7.6 volts across the plug with the engine running. Is this about right? I read some where that it's ment to be 12v?
    Dec 2014
    coopers plains, QLD
    Spooky......
    I also went to bunnings and made a boost leak tester. Used a pvc cap and a tyre valve insert sealed with epoxy
    I am in the opposite situation. Pumping air through I get about 3-4 psi. I've checked everything on the TIP, pancake pipe, used soap suds but it just wont hold any pressure. Oil cap off and the pvc cap is on the inlet just before the maf
    Any ideas?
    Apr 2015
    Wollongong
    Did you take out the hockey puck looking thing and cap it off??
    Dec 2014
    coopers plains, QLD
    Read a couple of diys and didn't see that
    &#%% sake, was pumping like a loon for ages
    Apr 2015
    Wollongong
    haha yeah i was doing it for a bit like... okay my intake is ****ed... then i was like, wait... im a retard hahah ended up being all g though.
    Dec 2014
    coopers plains, QLD
    Haha
    So you cap off the port below the puck and also the inlet to the puck?
    Apr 2015
    Wollongong
    Quote Originally Posted by elcono View Post
    Haha
    Nah you can just cap off the port on the inlet pipe, you can just put the hockey puck to the side it doesn't need to be capped.
