Page 9 of 10 FirstFirst ... 78910 LastLast
Results 81 to 90 of 95
Thread: SUCCESS!: How to make a new key incl. transponder
  1. #81
    Jul 2013
    Melbourne, VIC (NE 'Burbs)
    nope
    This thread is located in the MK4 section - i'ts not applicable to later models unfortunately. Probably going to need to visit the stealership.
    2003 Bora MK4 V4/2.0L GL
    [N/E MELB] VW MK4 Immo Key Recovery & Coding
  2. #82
    Mar 2011
    Gold Coast QLD
    Yes that later car will need more advanced tools. There is a guy on eBay in Sydney who has the AVDI tool to code keys to newer model VAG AG cars. Just look up VW key on ebay.com.au, it's the picture with lots of keys, I think he charges $100 for a new key and includes coding to your car. IIRC he is a VW tech and does this as after-hours work on the side. Good luck
    - 2011 Multivan T5.2 - 2,0L 135kW BiTDI. Mod info here
    - 2008 Tiguan 5N 103TDI 4MOTION. Mods: RNS510 | Colour MFD | MFSW | LED tail lights | Mirror LED | Footwell LED
  3. #83
    Oct 2013
    Eastern Melbourne
    So how does one code in a new transponder if the old one doesn't work and you only have 1 key?
    Currently my door locks are stuffed (surprise!) and I can only open the car via putting the key in the bootlid.
    How can I get the transponder to work considering my old one basically self destructed? Is a vag-com the only way?
    Quote Originally Posted by MightyCarMods
    I'd rather lose by a mile because I built my own car, than win by an inch because someone else built it for me. Your car is your story, so don't let someone else write the book.
    -| "Laura" - 2001 Bora 4-motion (now sold) |-
  4. #84
    Apr 2015
    Five Dock, NSW
    Quote Originally Posted by YellowLemon View Post
    Thanks for the suggestion. It looks to me like the chip (transponder) is different to the Skoda Octavia RS 2007. I could very well be wrong however, so I've sent an email to check.
    vw_parts_aus is his eBay username.
  5. #85
    Oct 2014
    Does the transponder chip require power?
    If not, would it be possible to dig the chip out of my working key and glue it inside the cowl around the ignition? And then just use any key I get cut?
  6. #86
    Jul 2013
    Almost definitely possible - but that just means your car effectively has no immobiliser. I think that means that the car may do things like no longer self lock, and the lights on the doors may not flash any more when the car is locked. Not sure...
  7. #87
    Quote Originally Posted by Lobster View Post
    The transponder does not need its own power supply as it is powered by induction through the key reader. If you glue the transponder chip to the key reader this will work but I highly advise against it for a couple of reasons.
    Firstly and most importantly, it will void your insurance. Your car is fitted with an immobiliser system to comply with the ADR, by gluing the chip to the key reader you are bypassing the immobiliser system, also making it easier to steal. IF your car were to get stolen and the insurance company had it investigated to see how ( It happens) then they would see that the system was bypassed, therefore you wouldn't get see a cent of your insurance money.
    Secondly, if you then get another key that has a transponder chip in it and try to start it with this key, even if it is not programmed, it can cause issues with the immo system, sometimes it might start, others it wont and eventually it will go into a lockout. if you don't know how to reset the lockout then you will be waiting a while with a non running car.
    And last, if the chip falls off ( I have had this happen a few times) then your car wont start, if the chip is lost or damaged it will be bad news for you to get it going again.
    I know that it seems like a lot of money to get a spare key and have it done properly but I suggest getting a quote for your car if you had no keys. Through a Locksmith it will get expensive as you need a valid key to gain access to the immo system on a lot of these newer cars, there are ways around it but the dollars add up. The other option is the dealer which not only will you be waiting 2 weeks without your car, you need it towed to the dealer.. Can you be without your car for a couple of weeks?
  8. #88
    Munno Para West Adelaide
    Quote Originally Posted by AALocksmiths View Post
    Hey mate Ive got a key fob that came with a ccm im installing into my golf but the led on the keyfob doesnt light up anymore, does it mean its stuffed? Ive changed the batttery but still nothing. Had to wire in the ccm as my car originally only had a one plug ccm and swapped it out to a two plug and wired in the power and antenna side of it. Can I swap over the top of my old key and use a new transmitter bottom part to work?
  9. #89
    What car is it on?
    The remotes can be reused so you can have your original remote coded into the car. If the LED isn't lighting up then there is a big chance that it's stuffed. They can also put out a frequency and still not work.
  10. #90
    Mk4 golf. Atm im trying to get a 433 mhz system (from a bora) to work as the part number starts with 1J0
    I did try a GTI system which is 1c0 but wiring is all different and is 434mhz. I switched the batteries around and it flashed once but never didnit again. Anyway to check the chip?
