from carsales.com.au
04 Bora:
Engine description Six cylinders, 15 degree V-formation, DOHC, four valves per cylinder, variable valve timing, all alloy
Capacity (cm3) 2792
Compression ratio 10.5:1
Maximum power 150kW @ 6200rpm
Maximum torque 270Nm @ 3200rpm
96 Golf VR6
Engine description Six cylinders, 15 degree included angle V-formation, chain driven DOHC, cast iron block with cross-flow alloy head
Capacity (cm3) 2792
Compression ratio 10.1:1
Maximum power 128kW @ 5800rpm
Maximum torque 235Nm @ 4200rpm
03 Golf R32 (V6)
Engine description Six cylinders, V-formation, chain driven DOHC, four valves per cylinder, variable valve timing, cast-iron block, aluminium alloy heads.
Capacity (cm3) 3189
Compression ratio 11.25:1
Maximum power 177kW @ 6250rpm
Maximum torque 320Nm @ 2800-3200rpm
there was no listing for an 03 Bora (figured 04 would be close enough), and no listing for a VR6 of the same year, closest i could find was the '96 golf
