Results 1 to 10 of 14
Thread: Stupid question?
    Sep 2007
    Syd, Northern Beaches
    Stupid question?
    Hey fella's
    Been reading over a few posts. Just wondering, is the VR6 engine identicle to the Bora 4motion V6's of the same year?
    Nathan
    (]/_ O _____ O _\[)
    "'(O8o)=\X/=(o8O)
    [__|========|__]
    Aug 2007
    newcastle australia
    from carsales.com.au
    04 Bora:
    Engine description Six cylinders, 15 degree V-formation, DOHC, four valves per cylinder, variable valve timing, all alloy
    Capacity (cm3) 2792
    Compression ratio 10.5:1
    Maximum power 150kW @ 6200rpm
    Maximum torque 270Nm @ 3200rpm
    96 Golf VR6
    Engine description Six cylinders, 15 degree included angle V-formation, chain driven DOHC, cast iron block with cross-flow alloy head
    Capacity (cm3) 2792
    Compression ratio 10.1:1
    Maximum power 128kW @ 5800rpm
    Maximum torque 235Nm @ 4200rpm
    03 Golf R32 (V6)
    Engine description Six cylinders, V-formation, chain driven DOHC, four valves per cylinder, variable valve timing, cast-iron block, aluminium alloy heads.
    Capacity (cm3) 3189
    Compression ratio 11.25:1
    Maximum power 177kW @ 6250rpm
    Maximum torque 320Nm @ 2800-3200rpm
    there was no listing for an 03 Bora (figured 04 would be close enough), and no listing for a VR6 of the same year, closest i could find was the '96 golf
    Sep 2006
    Australia?
    The vr6 bora which you talk about is the elusive 24V, god damn I want one! The mk3 is only a 12V and the r32 is a 3.2 litre compared to a 2.8L.
    In the states alot of Golfs came with the 24V 6ixers, but they are pretty rare themselves!
    Sep 2007
    Thanx guys! So the bora V6 has the same motor as the US MK4 Jetta VR6? It sucks, why cant there be so many performance shops over here as there are in the states. Parts are so cheap over there!
    (]/_ O _____ O _\[)
    "'(O8o)=\X/=(o8O)
    [__|========|__]
    Sep 2006
    Australia?
    I agree with you mate, its hard here but **** happens the market just isn't big enough here for all
    Also you just have to be careful when purchasing parts for the fact that they are left hand drive as we are right hand drive
    Sep 2006
    West Sydney
    There's also a Mk4 Golf VR6 with the 24V. That may be the same as the Bora VR6 and your 4-Motion?
    Aug 2007
    Perth, Australia
    Quote Originally Posted by rayray086 View Post
    I think its the same engine less 4-Motion
    1991 BMW 318is RED E30
    Sep 2006
    Australia?
    They had the 24V in a Golf but they weren't 4Motion they were still front wheel drive!
    Apr 2006
    they came in the 4motion, just like the mk3 syncro.. there is also a VR5 golf in europe..
    Oct 2006
    Yes there was a private import mk4 golf 4motion v6 for sale that someone brought to attention on this forum. The mk3 synchro had a 2.9L motor too
