Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: Strange Ticking Noise :S
  1. #21
    Quote Originally Posted by JedR32 View Post
    Damn, legit? haha
    I'd probably need to replace all 4 if one has gone wouldn't I?
    nar don't think its necessary to replace all 4 at once
    What's labour like on 4 wheel bearings?
  2. #22
    Apr 2009
    Newcastle NSW
    Wheel bearings can make many wonderful noises when there gone. Ticking is one noise they can make. If it is the bearing ticking your hearing it will probably be more prominent at speed.
    As for cost of repair, I have no idea ?
  3. #23
    Jun 2011
    Pull your wheels in and out. If there is movement your bearings are shot
  4. #24
    Mar 2012
    Brisbane, Queensland
    I'll have to try that tonight, and see how much movement there is.
    Could a CV Joint also make this noise?
    No. 164 - HPA Competition Haldex Controller, KW V3's, Southbend Stage 2 Singlemass Flywheel, Simota Racing Air Intake
  5. #25
    Mar 2012
    SO I took the car into my mechanic today. Unfortunately we couldn't figure out what it was.
    However! Good news is that my wheel bearings and CV joints are all A Okay
    So I am back to square one
  6. #26
    Mar 2012
    It's getting louder
    And I can hear it on both sides of the car now.
    Any ideas????
  7. #27
    Jul 2007
    Brissy
    It's getting louder
    Any ideas????
    I had a strange noise, turned out some of the crown wheel rivets had sheared.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
  8. #28
    Mar 2012
    What was pricing like on these?
    Anyway I can check them myself?
    Thanks!
  9. #29
    Feb 2007
    I had a RHF wheel bearing go. Ticking sound was there under light load when turning left, became increasingly louder and I could feel it through the steering at higher speeds on constant radius bends at over 80kmh. Just before getting it replaced, it got to the point where it started to sound like the wheel nuts were loose - almost to the point of being a banging sound - when cornering hard.
    If your mechanic hasn't taken it on a high speed test run then they most likely wouldn't have picked it up. Solitaire here in Adelaide test drove it at 40kmh and couldn't find a fault, noise, anything. So, I took the tech for a drive at a higher speed, reefed the wheel and then it was confirmed. Hope this helps!
  10. #30
    Aug 2007
    Perth WA
    First noise with the video in the engine bay is def the charcoal/carbon filter thiny. Normal.
    2nd video as you said, hard to hear - were you holding the phone near the gears at the end or by the door? Could it be something rattling in the exhaust perhaps??? Random guess!
    Had another thought - could it be the plastic inner guard liner flapping in the wheel arch? Pops out of place and starts bouncing against the tyre. Has happened to me several times!
    '04 BMP MkIV R32 #144
    search getnew
