How long does it make the noise for ? Minutes seconds ??
Hey guys,
i was just wondering if you guys would know anything or have herd about this problem before.
When i start my car for the first time each day (but if i started it, had it running for 5 mins then turned it off and started it again it would still make that noise) my engine makes a strange noise, its not a grinding or squealing noise i don't know what you would call it but its not at all good!
When its been running for 20 mins if i turned it off and started it again it wouldn't make a sound.
It doesn't sound like its coming from the fan belts and pulleys.
Could it be a bearing in the engine?
I would be really appreciated if someone could provide me with some help/information.
Thanks heaps Nick
For Sale my Black VW bora 4motion - http://www.carpoint.com.au/all-cars/...D-2186743&Cr=3
MK4 GTI - Sold
MK5 Jetta Turbo - Sold
it only like 2-3 seconds while its being turned over. thanks man, i will try and up load a sound clip.
Could be the starter motor not disengaging quickly enough.
Does it sound like this.
http://www.fallastarmedia.com/vortex...arternoise.wav
Previous discussions
http://www.vwwatercooled.org.au/f14/...-up-48477.html
http://www.vwwatercooled.org.au/f14/...-up-32221.html
MK4 GTI - Sold
If its a starter, it would make that noise all the time, regardless if the car is warm. What i understood is if the car is cold (ran for 5 min and restarted) the noise is still there. Could it be that its not getting enough oil pressure in the head so the lifters knock for a few seconds?
1991 BMW 318is RED E30
Yeah hydraulic lifters can make some cool noises before the oil thins out, is a symptom of all engines that use them and only gets worse with age.
2003 Bora 4Motion
You can check for if it's hydraulic lifters or something else. http://www.vwwatercooled.org.au/f28/...tml#post673710
This has been happening on my car for years, it does not happen every start but its worse in winter.
It is rare for it to happen with a hot engine.
In summer if might not do it for months at a time.
Lets see what the OP comes up with. It may be some thing else as others have suggested.
MK4 GTI - Sold
