Results 1 to 10 of 18
Thread: Strange noise from engine when starting my car.
    Hey guys,
    i was just wondering if you guys would know anything or have herd about this problem before.
    When i start my car for the first time each day (but if i started it, had it running for 5 mins then turned it off and started it again it would still make that noise) my engine makes a strange noise, its not a grinding or squealing noise i don't know what you would call it but its not at all good!
    When its been running for 20 mins if i turned it off and started it again it wouldn't make a sound.
    It doesn't sound like its coming from the fan belts and pulleys.
    Could it be a bearing in the engine?
    I would be really appreciated if someone could provide me with some help/information.
    Thanks heaps Nick
    For Sale my Black VW bora 4motion - http://www.carpoint.com.au/all-cars/...D-2186743&Cr=3
    Jul 2007
    Brissy
    How long does it make the noise for ? Minutes seconds ??
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    it only like 2-3 seconds while its being turned over. thanks man, i will try and up load a sound clip.
    Jul 2007
    Brissy
    Could be the starter motor not disengaging quickly enough.
    Does it sound like this.
    http://www.fallastarmedia.com/vortex...arternoise.wav
    Previous discussions
    http://www.vwwatercooled.org.au/f14/...-up-48477.html
    http://www.vwwatercooled.org.au/f14/...-up-32221.html
    MK4 GTI - Sold
    Quote Originally Posted by JustCruisn View Post
    i second start motor. Just sounds like something crunching/grinding?
    Aug 2007
    Perth, Australia
    If its a starter, it would make that noise all the time, regardless if the car is warm. What i understood is if the car is cold (ran for 5 min and restarted) the noise is still there. Could it be that its not getting enough oil pressure in the head so the lifters knock for a few seconds?
    1991 BMW 318is RED E30
    Apr 2011
    Ipswich, QLD
    Yeah hydraulic lifters can make some cool noises before the oil thins out, is a symptom of all engines that use them and only gets worse with age.
    2003 Bora 4Motion
    Adelaide hills, SA
    You can check for if it's hydraulic lifters or something else. http://www.vwwatercooled.org.au/f28/...tml#post673710
    Jul 2007
    Brissy
    Quote Originally Posted by balkanac View Post
    This has been happening on my car for years, it does not happen every start but its worse in winter.
    It is rare for it to happen with a hot engine.
    In summer if might not do it for months at a time.
    Lets see what the OP comes up with. It may be some thing else as others have suggested.
    MK4 GTI - Sold
    Adelaide hills, SA
    Quote Originally Posted by mybora View Post
    What viscosity oil are you using and how long is it in the engine for? If it turns to be the the hydraulic lifters make sure you use the engine flush when you do the oil change.
