Got any pics Dylan? I can't say I've seen anyone run just stock front valance with 20th the rest.
Printable View
brandon nero did it on the bora.
4mo lip, gli sides and rear from memory (same sort of deal as 20th) I did see a golf with it the other day too, ill grab the pic if I see it again
Wagenwerks did a trailer on his car http://vimeo.com/3619872
Sent from my GT-N7105 using Tapatalk
Yeah that does look sick on nero's bora I must admit. Maybe I should be looking into a 20th rear with no cutouts then try and source a 4mo front lip. Eri just ordered a 20th rear and apparently its genuine. Keen to see how she goes with it. Pretty cheap too.
Tried to lower the front a little bit more, no deal axle bind is horrible!!!! Raised it back up a tiny bit and it goes away. Looking to find a passenger side inner axle cup to try the cup mod. Anyone out there got a wrecked one they want to rip out the inner cup for me?
Bummer about the axel bind, I get nothing other then my cv about to explode.
Maybe work out what's different from the 2.0 to 1.8t
May have "relieved" a bit of my axel bind problems today. Last time I tried to loosen the engine mount bolts on the passenger side and push the engine towards the drivers side I didn't get it to move very far at all. Today I had a bit of spare time so I decided to try again. This time I actually got my scissor jack down in there, and with a few pieces of metal and a lot of smashed knuckles I managed to move the engine a LOT further. See the picture below.
Attachment 6421
Anyways seemed to have gotten rid of most of my bind. May possibly be able to lower the front a little bit more now.
I'm pretty jealous that you have no such thing dylan!!! so much easier to slam a 2.0! You don't even hit the frame?
winning! fair bit of movement by the looks!
nar, my car has self notched so much I barely touch anymore. subframe was like 1cm off the deck on 18s in the end I think.
was fine to roll around like that too.
Progress!! sump guard next on the cards ?? :P
My sump guard is my brake pedal...... I need to do this Attachment 6444
Looks like I will be hopefully getting the skirts painted this weekend. fingers crossed, soooo keen to see how it looks. May be able to drop the front a little lower as well now that I got rid of my bind.
Yep.. no more clenching with that battle plate :cool:
Skirts will be mint !! would like to see when done. Are you going to do yourself or get Micra to do
