its called voltage drop, if you have smaller gauge wire over a longer run you get resistance.
more resistance and less current can flow thru, which makes the voltage drop to make up for the lack of current.
believe me with big amps if you dont have big enough power feeds (and grounds) you can break/melt things, power side mosfets, power/earth wire, fuse holders i've seen it all.
