Results 1 to 7 of 7
Thread: Steering Arm
    Aug 2008
    Mawson Lakes SA
    Steering Arm
    On the way to work this morning my steering arm feel of the up,
    does anybody know what size / type or bolt is used to secure it to the hub ?
    Luckily was only travelling slowly when this happened,
    Apr 2008
    Quote Originally Posted by Vee-Dub View Post
    Fell off the hub?
    I should have access to a service manual tonight, I'll check the details and will let you know.
    Nothing to see here...
    Aug 2008
    Mawson Lakes SA
    Quote Originally Posted by Manaz View Post
    Fell off the hub?
    my bad yes fell haha,
    as in the bit it bolts onto behind the brake disk
    Apr 2008
    Not good - at least it happened at low speed, rather than in a high-speed sweeper!
    I think the parts you need are single-use - I'll check my service manual tonight, and will let you know the part numbers if I can find them.
    Aug 2008
    Mawson Lakes SA
    the bolt is still in the arm, all i need is the nut,
    looks like it would be a 12mm nylon locking nut or similar
    Apr 2008
    Almost certainly a locknut (with the nylon segment on the top of the thread, which is why they say they shouldn't be reused).
    Aug 2008
    Mawson Lakes SA
    Any idea on size ?
