On the way to work this morning my steering arm feel of the up,
does anybody know what size / type or bolt is used to secure it to the hub ?
Luckily was only travelling slowly when this happened,
Not good - at least it happened at low speed, rather than in a high-speed sweeper!
I think the parts you need are single-use - I'll check my service manual tonight, and will let you know the part numbers if I can find them.
Nothing to see here...
the bolt is still in the arm, all i need is the nut,
looks like it would be a 12mm nylon locking nut or similar
Almost certainly a locknut (with the nylon segment on the top of the thread, which is why they say they shouldn't be reused).
Any idea on size ?
