Subscribed.
You'll need another hub and bearing if you can't fix that thread for the wheel nut
Subscribed.
Congrats man! I will be following!
1990 Mk2 GTI 20vt - @mk2.20vt
So after returning from Europe, the car stuff has begun already. Over the weekend I managed to fit a Cupra R lip and cut the lower bumper grilles so they now serve their purpose as apposed to being closed up.; Also painted them black.
Wound down my front coils too but I want to go lower (about 7 turns left to the bottom) and during the week I'll be soaking the rear perches in WD40 as they're stuck and need a good whack to loosen them.
Done anything about your gearbox? Priced it up with a shop? I've gotta do mine soon but scared to get a quote haha. Also, got any links to decent lsd and fork upgrades? Clean looking r32 mate. Cheers
CURRENT: DBP Mk4 Golf .:R34 no. 187 (WOOKY)
Mods: C2 Motorsport Custom Tune | 268/264 schrick cams | Eurospecsport forged rods | JE forged pistons | Miltec Headers back | Higher compression | Engine fully ported | polished balanced crank | Sach Motorsport clutch | Single mass flywheel | Wavetrack LSD | Shortened 4th/5th/6th | etc etc |
Hey! Yeah, I've had a few quotes from a couple of different workshops around Sydney; most are quoting around the low $3,000 mark including labor so it isn't too bad I guess but mate, get it done before you start to wreck gears! And in terms of LSD, either go for a peloquin or wavetrack and USP Motorsports sell selector fork upgrade kits made of steel instead of brass, which is a worthwhile upgrade.
Good news for me was it was a belt that made a whinning noise on acceleration/deceleration which went away when clutch was in and not the dreaded gearbox dropso only about $350 fixed!
Oh thats sick! Hopefully mine is the same situation because I am not keen on forking out thousands just yet!
Haven't done much recently but have bought another cupra lip (other got destroyed) which I'm yet to install, had a headlight lens break, and discovered a flat spot on one of my tyres - very annoying to listen to. Need to upgrade my speakers as the rears dont work at all and I should be getting the gearbox rebuilt sometime very soon. Enough rambling, here's some pr0n:
