If it was the starter motor, then it would be screeching while you had the key in the start position. It could be the pre-engaged fork bearing, but these rarely fail. The same for the motor bearings.
If you have a manual, do you have the clutch pressed when starting? I know that some ECUs require the clutch to be pressed. If you can start the engine without pressing the clutch, try that. If there is no noise, then it is the clutch throw out bearing.
