Results 1 to 10 of 19
Thread: Stage 2 tune ecu mk4
    May 2015
    Volkswagen MK4 Instrument Cluster Stage 2 ECU KEY Combo Jetta GTI Golf GLI | eBay
    Will this ecu work in my car?
    Mk4 gti 2002. I have the supporting mods for a stage 2 tune.
    Cheers Jason
    Quote Originally Posted by TheOt View Post
    Cheers Jason
    That won't work mate and by the time you got it all here and fitted in the car you could have a Custom-Code tune from me.
    No ECU from an American GTI will work on an Australian one. They never got the AGU engine and we never got ME7 ECUs in ours.
    MK4 Golf GTI and 8L A3 Turbo with ME3.8 ECU. No ECU's opened during this tune up
    May 2015
    Thanks heaps for you help.
    How much do you charge for a stage 2 tune?
    What do you mean by custom-Code tune? Can the tune be customized?
    Cheers Jason
    Cheers Jason
    http://www.custom-code.co.uk/ You'll have to do some reading on the scene mate and catch up I wouldn't offer you a customised tune, as the cost wouldn't be in line with the extra power.
    There's nothing wrong with the file I already have.
    The price is $849.
    Mar 2014
    how much power can you get out of a stage 2 tune with full 3inch exhaust system?
    Quote Originally Posted by dcups(dailymk4) View Post
    If I saw one that made 210 hp at the crank I'd be very impressed. The exhaust system doesn't really hold them back, it's the turbo is very under sized.
    May 2015
    That's not much better than a stage 1 tune. What's the difference between them? Could you but the boost up to 20psi on the ko3 turbo? Is there a difference in fuel economy between the tunes?
    Would I have to send you my ecu?
    The reason there's not much power, is the size of the turbo. It can't be run harder, just makes heat. If you want more, you need a bigger turbo.
    Phase 2 makes more mid-range due to the better flowing exhaust.
    You can make it produce 20 PSI if you want to be changing it out often.
    The economy will be much improved over stock on either tune. You'll not see that around town really though. If you were driving out in the sticks, you'd see a good improvement in the distance you got on a tank.
    Jan 2014
    Narangba QLD
    I recently got stage 2 from Gav and highly recommend it, the difference is slight between 1 and 2 but it is noticeable.
    I also upgraded to a K03s turbo which is only slightly bigger but did help a bit.
    the thing you have to ask yourself when choosing stage tunes is basically..
    stage 1 is for a standard car which you want a bit more power.
    stage 2 is when you have the usual bolt ons (exhaust/down pipe and maybe a pod filter etc(not needed but sound cool )
    stage 3 is when it gets serious, you need many alternate components(turbo,manifold,fuel system,piping changes, clutch, some engine internals like con rods may need upgrading etc) which is a BIG jump in power but also cost.
    stage 2 is plenty of a daily street car where you don't want to be too concerned about breaking components
    I am currently getting 7.1l/100km in my mk4 GTI stage 2 with k03s and 3" down pipe and pod filter.
