Results 1 to 7 of 7
Thread: Vag tacho - brisbane
    Jun 2009
    Manly Qld
    G'day,
    Would anyone be kind enough to help me program my remotes for my Mk 4 Golf in Brisbane?
    Happy to meet at your convenience and can bring a laptop no drama's.
    Will need the Vag Tacho lead and the required disc (if applicable).
    Be very grateful.
    Thanks
    Matt
    May 2007
    Quote Originally Posted by gordymatt View Post
    G'day,
    Be very grateful.
    Thanks
    Matt
    Hey, contact JMAC (Jimmy) he will sort things out for you!!!
    Jun 2009
    Manly Qld
    It's all good, I opted to buy a Vag Tacho instead.
    Aug 2007
    Vagtacho to code remotes? If u have 2 remotes and 2 keys you don't need vag tacho or vag com,. You can do without any software
    Good luck
    Jmac
    Alba European
    Jun 2009
    Manly Qld
    I have 2 spare remotes and one working key with a transponder that doesn't work.....
    I've followed the links on this forum and I was led to believe that this was the only way to do it.....there's a thread in the Mk 4 forum explaining step by step how this needs to be done and everything suggests you need a vag tacho cable.
    As i am inexperienced in programming replacement remotes i turned to this forum for assistance.......
    Are you advising that the Information on this forum is incorrect? If so, maybe I do require your services.....
    How much to programme 2 x new remotes?
    Aug 2007
    Dont always take a forum as gospel many have with massive fails, to do it without software all you need is 2 keys that open ie one that goes into the ignition and one that can manual lock the doors, even the plastic valet key will do, then i can do it if the remotes arnet faulty, no probs. however if you have a key that has a non working transponder then you will have a non starting car, this the case?, ill chat to you mate to get the picture. Reading this now you have 2 remotes which includes the keys?? Then the transponder need programming, that needs an eeprom reader like vag tacho which i have, and the remotes will be manual or VCDS, yet another bit of software. Ill chat to you mate
    Pm sent
    Alba European
    Aug 2011
    melbourne
    what the ****?
    '02 GTI (clicky) - REFLEX SILVER - VIEZU race tune. VAR design 2.5inch stainless steel dump pipe with 100cell cat into 2.5" billyboat stainless cat back, Forge TIP, N75, Audi DV, ghetto CAI, FK-AK s coilovers, tunerdone LEDs, Clarion CZ301E sound stage.
