Results 1 to 10 of 10
Thread: Squeaky Clutch!!!
    Aug 2012
    melbourne
    Squeaky Clutch!!!
    Hey can anyone help me with a squeaking clutch pedal on my MK4 GTI..I have got under and sprayed the spring behind the pedal with WD40 but no luck with that... any suggestions would be appreciated..Cheers
    Jul 2007
    Brissy
    Try some dry lube on the push rod and the pivot point. The spring is probably not the issue.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    May 2009
    Canberra
    I've got the same problem, just started this morning.
    2009 Tiguan TDI and 2007 Passat TDI
    Mar 2012
    Sydney NSW
    Can you chase the noise down to a particular area?
    Under dash / footwell or engine bay ?
    Common on cars with a "squeek" with the depressing of the clutch pedal , emitted from the release bearing (lubrication drying up / bearing failing) or the pressure plate itself. Some things to consider
    Jun 2011
    Could be the pedal itself?
    Jul 2007
    Brissy
    The clutch master cylinder is built into the pedal under the dash.
    The spring helps to reduce the effort needed to disengage the clutch, it helps the pedal go down, not up as some might think. The up is provided by clutch itself via hydraulic pressure.
    Here is the pedal assembly
    For more detail check out this DIY
    Clutch Master Cylinder DIY Replacement 1.8T Golf MK4 - uk-mkivs
    MK4 GTI - Sold
    Dec 2008
    Northern Suburbs
    It will be the clutch pedal pin bushes (number 8 ) obviously your pedal isn't plastic as pictured but it was just a way to show what you need, you could pull it all apart and grease it and see if that works but you need a tool to put the clutch spring back in
    Think the bush as above or the plastic 'holder' (number 25 above)
    mine started after I had the pedal out to be replaced.
    Aug 2012
    melbourne
    Yeah i have chased down the noise it seems to be coming from the footwell up in the pedal....id rather not pull it apart if i could get away with it..
    Quote Originally Posted by 18TMK4 View Post
    I'd advise against taking it out... They are a pain, trust me, have done one
