Results 1 to 8 of 8
Thread: Squeaking/rattling centre console
    Apr 2008
    Hi all,
    I've got a squeaking/rattling centre console (the bit that surrounds the gear shift and runs up into the ashtray) on my 2003 Bora V6 4Motion. It seems from some reading that this is relatively common, though I'm yet to see any reference to a potential fix.
    Anyone have any ideas?
    Nothing to see here...
    Dec 2007
    Auckland, New Zealand
    is the ash tray rattling or the actual surround? try some 3M foam tape where the 2 dash and gearbox surround meet.
    1999 Golf GTi - SOLD
    2005 Golf GTI (2 Door) - SOLD
    2014 Octavia RS400 Combi
    1997 Golf GTI (Daily/Track Hack)
    Apr 2008
    Quote Originally Posted by Fizz View Post
    The actual surround. I can wiggle the whole piece a centimetre or so each way with my hand (or by resting my leg on it). The squeaking does seem to be from where it touches other parts, foam tape might do the trick!
    Dec 2007
    sounds like u might be missing a screw or something as it shouldn't be loose.
    Apr 2008
    I had another look last night, and the distance it moves isn't as bad as I thought (more like half a centimetre tops) - but the squeak/rattle is certainly bad.
    Will be trying the foam tape...
    Melbourne, Australia
    Same same, the wife's Golf had a similar problem. Squeaking like a mouse in a blender.
    Rather than foam tape, I used self adhesive felt tape - about 1.2mm thick
    It was a real PITA to find a supplier - but located one in Melbourne.
    JJ Davies
    Only problem is that you had to buy a slit roll.
    Only A$40 but I had enough to do the all the interior squeaks.
    Hope this helps.
    Golf 1.6 Auto
    Bog-standard (wife's daily driver)
    Jun 2006
    Orange NSW
    If you have annoying squeaks in the plastic parts of the dash and you are unable to use something like foam or felt, try a very small squirt of silicon spray in the join. Works a treat.
    Nov 2007
    Coffs Harbour
    Quote Originally Posted by Manaz View Post
    Hi all,
    WD40 spray around all the edges....i just done mind it was pissin me off IT WORKS
