thoughts, links, Ideas????
After the 1.8T swap into my mk4 (originally a 1.6) I have found that the speedo is reading about 10 kph under the actual speed.
This was checked with a gps of known quality. And a speeding ticket...
So at an indicated 100 kph I am actually doing 112 kph.
Other speeds: first number is indicated, second is actual:
20 27
50 58
60 70
80 90
100 112
You can change small errors via vagcom, but can you sort one this big?
I am running standard wheels, so nothing is going on there: 205/55/16. Original cluster, new ECU (the one that came with the engine)
I have searched here , vortex and ukmk4 sites and cant seen to find what I am after.
Speed sensor change perhaps - but which one?
Vagcom thinks the car is going it's indicated speed
Please help, this is a pain
I've been told that you can get your speed o re calibrated so might look into that? Might just be due to a different method in the speed sensors between engines?
2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff| Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
I'm thinking so as well, but was hoping for a software solution I could do....
