Results 1 to 4 of 4
Thread: speedo calibration problem ...
    Jul 2009
    Geelong, Victoria
    Question speedo calibration problem ...
    After the 1.8T swap into my mk4 (originally a 1.6) I have found that the speedo is reading about 10 kph under the actual speed.
    This was checked with a gps of known quality. And a speeding ticket...
    So at an indicated 100 kph I am actually doing 112 kph.
    Other speeds: first number is indicated, second is actual:
    20 27
    50 58
    60 70
    80 90
    100 112
    You can change small errors via vagcom, but can you sort one this big?
    I am running standard wheels, so nothing is going on there: 205/55/16. Original cluster, new ECU (the one that came with the engine)
    I have searched here , vortex and ukmk4 sites and cant seen to find what I am after.
    Speed sensor change perhaps - but which one?
    Vagcom thinks the car is going it's indicated speed
    Please help, this is a pain
    My build thread here: 1.6 sr into 1.8T http://www.vwwatercooled.org.au/foru...-8t-63249.html
    Jul 2009
    Geelong, Victoria
    thoughts, links, Ideas????
    Mar 2010
    Lesmurdie
    I've been told that you can get your speed o re calibrated so might look into that? Might just be due to a different method in the speed sensors between engines?
    2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
    Jul 2009
    Geelong, Victoria
    I'm thinking so as well, but was hoping for a software solution I could do....
