Hi Fuzz
Have you had your key coded yet?
Thanks Matt
Hi Fuzz
Thanks Matt
geez that's expensive... had a key replaced for our 2003 nbc as the little chrome piece that you put on the ring broke off.. $120 for the new remote and they programmed it while i waited. took all of 30 seconds.
Can anyone tell me what mhz the Australian keys use?
Thanks Matt
I two didnt recieve a spare key with my new beetle..We rang up and they wanted to charge $380 for a new one and 8 weeks delivery :S
If its the same as the 2001 Model, then its 434Mhz
also the serial code should be:
HLO 1J0 959 753 AG
You can find these details on your key fob, by pulling the top part (the bit with the buttons) off the bottom (the bit with the key). Just pull at either end but a bit of force, and they will separate in the middle. It will appear on back of the top part of the key fob.
