Results 1 to 9 of 9
Thread: A source for the dreaded door microswitch
    Nov 2006
    Brisbane Qld
    Here is an ebay source for the prone to fail door microswitch.
    http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItem&item=160371346069&ssPageNam e=ADME:B:FSELE:1123
    Ebay user: carlicious-parts
    I'm sure Jaycar or someone would have something similar here.
    At least this is what it looks like so someone might be able to match up a local equivalent and post the details.
    Much cheaper than a new door lock!
    Apr 2008
    Would this be to help the annoying problem where it keeps popping up when locked?
    2000 Mk IV GTI
    May 2007
    Moonee Ponds
    Thx Graeme, I need to do mine and have a spare so will save me searching !!!
    Audi B4 80 Q V6 '94 Race Car !! KEGGED
    Audi B4 80 V6 Avant '94 Only one in the country that I know of !!! KEGGED
    Subaru Forester XT '06 Genome Exhaust/Car-PC/Boost Gauge/Oettingers !
    --VW Bora V6 4mo '01 Gone
    Albury, NSW Australia
    Quote Originally Posted by graeme86
    Yeah, tell me about it. Drivers side failed just out of warranty, but VW picked up the tab (cheers!), but it died about 14 months later. I put up with it for a few weeks, but kept leaving my headlights on. Finally, I paid over $500 to get it replaced - I get the car back from the dealers and the passenger door stops working that night.
    Considering I work with electonics, I should have just fixed it myself. Finding time to remove the mechanism is the hardest part!
    79 MK1 GLD
    03 MK4 GTI
    94 993 Carrera
    May 2009
    Perth
    I have a problem where occasionally one of the rear doors needs a second 'blip' to unlock it. Is it this that's causing the problem?
    Oct 2009
    sydney
    failed door lock fix ?
    I've been told its 3-4 hundred buck job to get the rear door lock sorted, is this a fix for that??
    May 2007
    Moonee Ponds
    Mate, it depends on teh problem. There is a fantastic guide on vwvortex if you dont get any further love here.
    P.S.
    this topic has been added to mkiv 4 faq.
    Quote Originally Posted by Golf4 View Post
    Oct 2009
    sydney
    cheers, I will look into VW Vortex as well. Anything I can do to save paying VW Village any more of my hard earned coin.
    Castle Hill, NSW
    Post Alternate mircoswitch
    I just replaced the microswitch on my 2003 Mk4 drivers door using the VWVortex DIY guide and a Bentleys manual. I sourced a completely different microswitch through RS components, same manufacturer (SIAI-Burgess) but different design. In my case the mounting lugs for the microswitch had deformed and prevented the locking cam from actuating the switch. I ordered a switch with mounting holes similar to those in the locking mechanism but I still had to file one hole and redrill the other to acheive the correct location of the switch.
    I used a SIAI-Burgess XCF3-Z1, RS components stock number 4728162. Wired it up as normally open. One tip if you are using the VWVortex guide, be really careful removing and installing the inner door panel/window carrier, I scratched the tint on my drivers window a bit during the job.
