Results 1 to 10 of 19
Thread: So Many Questions...
    Feb 2007
    Sydney NSW
    OK I've got a little list of questions that have been on my mind for ages so if anyone knows the answers that'd be awesome.
    1) The little red light on the drivers side door lock - how do you make it flash when the car is locked? Is the immobiliser still on even if the light is not flashing? Someone told me to turn the key 3 times or something?
    2) What RPM approx does your GTI sit on when idle?
    3) On the original stereo, when I hit the >> or the << it skips to the next track but I can't search within that track. ie I can't fastforward to hear a hot guitar solo, or rewind within a track. Hitting the arrow button just skips to the next track? Can the factory stereo search and if so, how?
    4) How do you change the clock on the stereo?
    5) When I bought the car the guy only gave me 1 key. Where do I get another?
    6) When I accelerate hard, the front of the car skips and jumps around because the wheels can't grip (I only tried it once)
    Would wider/bigger tyres make a difference or is this a suspension mod? Or what can be done to get the power to the road instead of hopping around?
    OK I think that is all the niggling things so far.
    Thanks in advance.
    Oct 2006
    Quote Originally Posted by blue_reality View Post
    1-The Red light should flash when you've locked your car via the remote/or key. If it doesn't it means one of your locks are playing up and your immobiliser isnt activated (so ive been told). Get the car scanned by VAGCOM by bug_racer would be my opinion with that.
    2- i dont remember! lol, around the 800-1200 mark depending on aircon and what not as well
    3- the stock stereo as far as i knew didnt skip forward only next track, POS! (piece of ****)
    5- from VW itself, otherwise bug_racer can organise you another and i think from memory they are $100+
    6- when i accel hard my wheels still spin/bounce but not as much as before i did the dogbone mount bushes, larger wheels of course gives you better traction most definately/better tyres too
    Thanks in advance.
    Hope that helps you out a bit...
    What’s behind you doesn’t matter..
    Feb 2007
    Sydney NSW
    Aha, when I use the central locking button inside the car, the passenger lock always bounces back up again as soon as I've hit the button. I thought it was some Euro Safety device LOL
    gpk_gti Guest
    mine bounces back up again too,but its still locked...
    changing the dog bone mount will make it better but you will get vibrations for about 1000k untill the settle in. as for larger diameter rims,you will trade off the bouncing and big tyre spinning and get more top end.some dish 17's with some really sticky tyres will be much better!!!
    Sep 2006
    Brisvegas
    Does thi mean if you press it in and hold it , it still wont fast forwrd.
    For Sale 2006 VW Polo GTI
    Have a Look
    CUSTOM CODE
    Phase 2
    Feb 2007
    Sydney NSW
    Quote Originally Posted by shaneth View Post
    That's right! It doesn't fast forward
    Feb 2007
    Sydney NSW
    Anyone know how to change the clock on the stereo?
    jbot Guest
    did you read your car manual?
    Ok...ignore my first method, turns out it IS totally wrong.
    Here's how to change the time:
    1. Turn your ignition on so your stereo switches on at least.
    2. Push the Volume knob in once. The display should change to the time
    3. Push and HOLD the volume knob in again, you won't see any change on the display
    4. While still holding the volume knob in, press the next track (>>|) and prev track (|<<) to change the hours and minutes, respectively. The clock is a 12 hour clock and you can only scroll up through the digits using these buttons.
    5. Once you have the correct time set, release the volume knob, wait a few seconds and the display should change back to your CD/radio info. All done!
    As a side note, I just discovered you can switch the time display off all together. From the normal stereo display, press and HOLD the volume knob in. After about 5 seconds it should say "Time Off". To turn it back on, do the exact same until it says "Time on".
    Enjoy!
    If you push the volume knob on the stereo in, it should show the time, then press again it goes to bass -> treble -> blah blah.
    So, press it once to get the time displayed. Then I *think* you press it again, but hold it in for a few seconds. From memory the hours number will start flashing and you can change it by turning the volume knob, or with the track up and down buttons (don't remember which).
    This whole procedure may be totally wrong...will have to check later today when I head home.
