Originally Posted by
blue_reality
OK I've got a little list of questions that have been on my mind for ages so if anyone knows the answers that'd be awesome.
1) The little red light on the drivers side door lock - how do you make it flash when the car is locked? Is the immobiliser still on even if the light is not flashing? Someone told me to turn the key 3 times or something?
1-The Red light should flash when you've locked your car via the remote/or key. If it doesn't it means one of your locks are playing up and your immobiliser isnt activated (so ive been told). Get the car scanned by VAGCOM by bug_racer would be my opinion with that.
2) What RPM approx does your GTI sit on when idle?
2- i dont remember! lol, around the 800-1200 mark depending on aircon and what not as well
3) On the original stereo, when I hit the >> or the << it skips to the next track but I can't search within that track. ie I can't fastforward to hear a hot guitar solo, or rewind within a track. Hitting the arrow button just skips to the next track? Can the factory stereo search and if so, how?
3- the stock stereo as far as i knew didnt skip forward only next track, POS! (piece of ****)
4) How do you change the clock on the stereo?
5) When I bought the car the guy only gave me 1 key. Where do I get another?
5- from VW itself, otherwise bug_racer can organise you another and i think from memory they are $100+
6) When I accelerate hard, the front of the car skips and jumps around because the wheels can't grip (I only tried it once)
6- when i accel hard my wheels still spin/bounce but not as much as before i did the dogbone mount bushes, larger wheels of course gives you better traction most definately/better tyres too
Would wider/bigger tyres make a difference or is this a suspension mod? Or what can be done to get the power to the road instead of hopping around?
OK I think that is all the niggling things so far.
Thanks in advance.
Hope that helps you out a bit...
