Results 1 to 2 of 2
Thread: SMIC - Any news ?
    Dec 2006
    SMIC - Any news ?
    BoostFactory:
    http://boostfactory.net/product_info...products_id=77
    Forge Motorsport:
    http://www.forgemotorsport.co.uk/con...duct=FMINTMK4S
    Gains over stock SMIC
    Size increase: 27mm x 5mm x 15mm - HAHAHA! (2.7cm x 0.5cm x 1.5cm)
    Pressure loss reduction: 2psi
    Air temp reduction: 6-9 DegC
    TyrolSport:
    http://www.tyrolsport.com/vwperformance.htm
    Any others ? Pros and cons with experience wanted if possible.
    And I DON'T want a front mount...........
    -DIDZ
    BF USD$550 AUD 616
    Forge UKP420 AUD 1000
    Tyrol USD 750 AUD 909
    All plus shipping
    I had a front mount made for my A3 for 1600 all in fitted.
    If you are adamant not to be doing the FM then I'd be going for the BF one. I bet you could get one made locally to go in the same space as the std one. Thing is there are other restrictions that need looking at too, like pancake pipe and TIP. If you start adding in the cost of a pancake replacement which I no longer need then the FMIC fitted looks better all the time.
    gavin
