Page 23 of 31 FirstFirst ... 132122232425 ... LastLast
Results 221 to 230 of 308
Thread: Simon's 4-Motion Bora VR6
  1. #221
    Aug 2011
    melbourne
    im guessing i missed a post, is the burn mark from a weld job?
    '02 GTI (clicky) - REFLEX SILVER - VIEZU race tune. VAR design 2.5inch stainless steel dump pipe with 100cell cat into 2.5" billyboat stainless cat back, Forge TIP, N75, Audi DV, ghetto CAI, FK-AK s coilovers, tunerdone LEDs, Clarion CZ301E sound stage.
  2. #222
    Mar 2009
    Wagga Wagga
    Quote Originally Posted by leighaus View Post
    Nope, burn mark is from the tyres on my BMW wheels rubbing on the body
    Burn is on both sides, although the drivers side is covered by the coolant bottle.
  3. #223
    Aug 2011
    melbourne
    hahahaha, thats a story for the grandkids if i ever heard one.
    If your pod sat back towards the firewall a bit more, id suggest you create a box for it, which would start right where you want it covered up. Otherwise, you could mount the catch there, but it would stick out like dogs balls.. Need any fuse relocation?
    Or mask and paint just the arch. Shouldnt be much of a job.
  4. #224
    Mar 2009
    Wagga Wagga
    That makes me wonder if I can put the fuse box that usually sits on the battery over it....... Hmmm
  5. #225
    Quote Originally Posted by trickysimon View Post
    Should probably keep that near the battery
  6. #226
    Mar 2009
    Wagga Wagga
    Why? The battery is in the boot. Just running the line straight to it, so doesn't really matter where I put it.
  7. #227
    Hmmm I thought the shorter the connect to important fuses like that the better? Maybe wrong though
  8. #228
    Dec 2012
    Sutherland Shire, Sydney
    That's a classic mistake - you need a fuse at the battery
    If the heavy wire to the fuse box ever get's cut or shorted it has access to a few hundred amps
    I've heard stories from auto electricians about the long wire to the fuse box glowing red and sparking and starting a fire
  9. #229
    Mar 2009
    Wagga Wagga
    Good point. Guess we could put another fuse at the battery?
  10. #230
    Feb 2014
    Batemans bay
    Put a battery master switch in but NOT a fuse or circuit breaker ....
    Otherwise your introducing something else to go wrong ....
    KISS... Keep it simple Simon ...
