Welcome aboard ![Smile](https://www.vwwatercooled.com.au/forums/images/smilies/icon_smile.gif)
I too have been doing my research on turbo vs supercharger.
Best 2 options are the rotrex supercharger kits, and the C2/Kinetic turbo kits, there seems to be a few reliability issues with the VF kits....
Rotrex is good because it puts less strain on cooling, and theres no permanent mods required ( oil feed holes etc), so installation will be easier.
But you dont the big midrange shove you get from the turbo, boost rises in line with revs, so you get peak power at high revs.
Turbo kits are great, but make a lot of heat and will require a fair bit more work to get installed. Advantage is if you want more power you can build the motor and wind the boost up!
Key for either is engine management, which si the #1 thing stopping me from doing it. Not sure if you have anyone who can realtime tune your ECU to suit, but we dont have anyone over here, so I need to look at about $4-5k for a decent standalone setup.
Current: '04 Astra SRI Turbo - EDS IPF Flash, 3" TBE, Quaife LSD
Previously: Bora 4mo, cams, coilovers, tune, exhaust, brembo's etc
