Results 1 to 6 of 6
Thread: Vw bora door plate removal
    Jan 2014
    Qld
    Hey guys, been trying for half an hour now can anyone tell me how to remove the metal plate on the inside of the door trim, i need to replace the door lock mechanism but i cant get this friccking plate off.. Seen a few tuturials but none are exact. Its a 2002 vw bora 4motion.. Excuse the crappy sideways photo from my iphone but this is what it looks like now.
    cheers
    Trent
    Attached Thumbnails Attached Thumbnails Vw bora door plate removal-image-jpg
    Feb 2013
    Have you removed the door handle blanks? If you haven't you'll need to as I think the latch is pivoted onto the plate. If you have and you've removed all the bolts you should be able to lift the plate up from the corner.
    Nov 2013
    Goldcoast QLD
    disconnect the window from its runner ( throw a black grommet under the window motor ), then undo all the bolts holding to to the door frame and then it just pulls off you may have to lift it up then and angle it forward a little then pull back
    Jan 2014
    Qld
    Quote Originally Posted by aaron001au View Post
    When the window is up i can see a blue plastic thing holding the window, and the black runner attached to the blue thing, but i cant seem to figure out how it comes off.. Sorry not being very clear at all haha
    Quote Originally Posted by Tl2ent View Post
    You don't need to take that off to remove the door lock itself. In the end of the door is a blanking plug. remove this plug and look inside. See the torx screw, undo it all the way. This backs off a locking ring and you can then just pull the lock out of the door. Easy.
    If you want the handle off the door, I can't help you.
    Although the steel panel is connected to the window, so you need to remove the 2 blanks and drop the window until you can see the bolts that hold the window. Once you have slackened them off, lift the glass up and the panel should be free.
    Jul 2007
    Brissy
    You have to remove the glass, release the lock module from the outer handle and the door frame.
    Then remove all electrical connectors and take the silver panel off.
    Check out these DIYs
    How to repair a broken window regulator mechanism (Edited 27/9/2009). - D.I.Y Guides and How to Instructions - uk-mkivs
    VWVortex.com - DIY - Replacing the front door window regulator clips and/or door lock module
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
