Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Short Shift kits.
    Jan 2008
    Canning Vale, Perth, WA
    I've gpt the dieselgeek in mine, and is brilliant. cant quite understand why this sort of thing isnt OEM
    Sigma 6 speed Short Shift Kit by www.dieselgeek.com
    US$195 plus around US$45 for postage. Then I had Quattro Motors instal it for me for $100.
    BDS, I'm in Canning Vale if you want to pop round and give it a try
    2007 Audi RS4 with: APR ECU Upgrade; JHM Quick Shifter; Milltek Catback and Downpipes; KW V3 Coilovers; Argon Creative Carbon Fibre Splitters
    Jun 2008
    Cronulla, NSW
    Not that any of you are thinking of it (who does?) but they are basically a one-time fit option. What i mean by that is that the alloy that Jim from DG uses is awesome but soft enough to burr and dint as you tighten the shifter ends around the shifter cable. The shifter cables have the appearance of being threaded (its not really a thread) so that the OEM shifter end can grip and stay on the cable. So the inside of the shifter end that accepts the cable starts out life as being all nice and smooth, but once it is tightened it engrains the thread of the cable, and becomes very hard to pull off again.
    I fitted my DG SS to my Mk5 TDI for about 6 mths and then took it off to install on my Bora, and it was simply sheer luck that I was able to re-fit it (after getting 2 blokes to have a crack at pulling it off the TDI). Somehow by luck it went on in the exact right place for adjustment too, so i absolutely fluked it.
    I have two pork-hands and was stil able to fit it. If i can, anyone can. Save your $100 and have a crack yourself.
    MY02 Bora V6 4Mo|Matte Black plastidip|VTDA|R32 Exhaust|R32 dampers and springs|TT pedals|R32 steering wheel|17" 8L S3 rims|R32 sways|Blue Haldex|EBC reds
    Aug 2007
    Perth, Australia
    i have the HPA front to back and side to side and its the best mod so far. its set to 40% reduction and it took awhile to get used to it but once i did i loved it. It was really easy to install and it came with proper instructions
    1991 BMW 318is RED E30
    May 2010
    Is the HPA a straight fit (no grinding), also is it alloy and how much did it set you back?
    Mk IV Golf GTI - BMP - GIAC chip, R32 wheels, KW coilovers, rear swaybar.
    Originally Posted by JoeVR
    I've never been a big fan of rotors, or really Japanese cars in general, so my choice would have to be..... an RX-8.
    Mar 2010
    Lesmurdie
    Hmmm, So does anyone tried the ecs one? Im thinking about the diesel geek one since so many of you reconmend it but since im allready ordering from ecs it will cut down on shipping costs.
    2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
    Aug 2007
    Camden, NSW
    Dieselgeek FTW! Fitted mine on Thursday. Awesome mod, has nice solid engagement
    03 MkIV GTI - K04-001, APR 2.5" TBE/TIP/Software, Forge FMIC, GFB DV+, Powergasket+, Dark Tint, 17" Bora Sport, Bilstein shocks, Eibach springs, BMC CDA, Dieselgeek SS, Hella Celis, R32 Alloy Trim...
    95 MkIII VR6 (sold)
    Dec 2007
    Brisbane, Southside...
    No grinding or anything on the HPA shifter.
    Cheers,
    Trent
    2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
    2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
    "Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
    Jun 2009
    no grinding on DG
