got the new suspension put in today (along with stage 2 refresh kit)
feels great even with the KYB's on the hardest setting.
can't really test it out properly as the roads are wet
little concerned about the ride height though.
i've read that they need to settle, but i've read different opinions on wether or not this is true.
the H&R sport springs are supposed to lower the front 38mm, and the rear 35mm.
the gti sits probably 15-20mm lower than a new stock golf (non gti, so 2.0 etc)
i measured the guard heights before and after
fronts: both have dropped about 10mm
back right: has dropped about 8mm
back left: has only dropped 1-2mm!!!
(and yes i tried these measurements at different places, and the back left was always 6-7 mm higher than the back right)
will give it some time and just hope that this "settling in period" is not a myth...
