remove the whole front grill ,vw badge pops out .. sand back with some paper and paint with black spray paint.
rear is popped off using a screw driver ... becareful!!! you have to get inbetween the rubber and the body work. its a double sided taped on.
use a dremel to remove plastic buttons(they are chromed ) and badge will come off. sand and then paint. glue back on and use some double sided tape to reapply onto car.
