Results 1 to 10 of 13
Thread: Shadow VW Logo
    Aug 2008
    Shadow VW Logo
    How do you go about blackening the VW Logo's front and back and removing the back badge for MKIV R32's.
    Looks pretty cool when i see it done,
    Thanks
    .:MKIV R32:.
    .:Reflex Silver:.
    .:80th of 200:.
    gpk_gti Guest
    remove the whole front grill ,vw badge pops out .. sand back with some paper and paint with black spray paint.
    rear is popped off using a screw driver ... becareful!!! you have to get inbetween the rubber and the body work. its a double sided taped on.
    use a dremel to remove plastic buttons(they are chromed ) and badge will come off. sand and then paint. glue back on and use some double sided tape to reapply onto car.
    Jun 2008
    Sydney, The Hills
    I just painted my rear logo, well not the chrome part, the grey plastic backing black to match my car. Everything gpk gti said is correct (using the dremel etc, and hot glueing the badge back onto the backing) HOWEVER, dont use a screw driver to remove the badge, you will scratch the paint, easiest thing is to get some dental floss and run it between the paint and the badge and it pops off! Do afew coats, and use wet and dry sandpaper in between every 2 coats to get it glassy smooth, i did this 3 times doing about 6-8 light coats, now it actually looks like the colour of the car, and it is glassy as! no orange peel
    hope it helps!
    Aug 2008
    Quote Originally Posted by gpk_gti View Post
    so u actually remove the two vw logos then sand and spray, then glue them back on?? Starting to sound like a very easy mod
    Thanks for the info guys
    .:MKIV R32:.
    .:Reflex Silver:.
    .:80th of 200:.
    gpk_gti Guest
    dental floss... the screw driver of the naughties! hehehehe
    Jun 2008
    Sydney, The Hills
    lol
    Aug 2008
    does anyone have any pics of their completed logo?
    .:MKIV R32:.
    .:Reflex Silver:.
    .:80th of 200:.
    Dec 2007
    Brisbane, Southside...
    Too much effort if you ask me and unless you're confident in your painting skills, too easy to stuff up.
    If I were to do it I'd just buy it from ECS or similar. Expensive yes but all depends on how you value your time.
    Cheers,
    Trent
    http://www.ecstuning.com/stage/edpd/...productID=3730
    http://www.ecstuning.com/stage/edpd/...productID=3729
    2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
    2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
    "Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
    Jun 2008
    Sydney, The Hills
    umm, i took a pic, and its not that helpful really, cant see it that well because of all the reflections. i only painted the backing plate to the logo, not the actual chrome piece. it now looks like it was painted with the colour of the car originally
    Aug 2008
    Quote Originally Posted by Treza360 View Post
    Cheers,
    Trent
    Doesnt sound like you!! lol
    Thanks for the info
    .:MKIV R32:.
    .:Reflex Silver:.
    .:80th of 200:.
