Up to a BAR is pretty normal on a chipped car, around half of that for a standard one.
Just curious to see who has upped the boost on their stock AGU engine to a safe level? Ie: how far above standard boost? I've searched the system at work and I can't even find what boost they run from the factory. Let alone safe boost levels on a stock engine.. regards brodie
So if I chip it 14 psi is safe.. other wise 7 psi for a completely stock engine.. how much boost do they run from the factory?
If you chip it, you get what the tuner writes into the software. There won't be a choice.
No tuner worth his salt is going to request too much boost. The Golf 4 GTI has been around for ages now and they are rock solid.
A standard one would be running 7-8PSI.
I see 25psi a fair bit and it hasnt gone bang (yet ;P ) been driving it like its stolen for over a year at this level .........
The motor is good for 300hp and 300lbs. The turbo isn't though.
kaneda -- is that on a k03, k03s or the k04? also, bigger injectors? and what tune?
k04 , 380's , giac
