Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Running issue need some help
    Sep 2008
    Townsville
    I recently had a gear box issue which took the car off the road for a little while...... seeing it was off the road i put in larger injectors, larger MAF and changed the software. Since getting the car back on the road Ive had a few issues with how its been running, with alot being due to vac/boost leaks.
    I have sorted all the vac/boost leaks but the car still plays up a little , so im at the point where i need some other opinions on what it could be.
    The issue i am having is that the car is missing @ cruise .....under load its fine no problems and idle is fine, but when you are cruising along it will miss every now n then and it seems that the throttle when lightly touched provokes the same response.
    So throw some suggestions at me what i should be looking for as im at the end of my knowledge.
    I will add that i only have a V-checker pro and no access to vag-com.
    Camden, Sydney
    Ignition control module? or Throttle body not been reset to basic settings?
    Sep 2008
    Townsville
    Ive done the throttle body rest a few times with no change.
    I would have thought if the ignition module was dodgy it would do it all the time not just @ cruise ?
    What are the plugs like Steve?
    Is it producing more power than before the changes?
    Townsvegas QLD
    I have tried 2 sets of plugs
    1 set of coper core plugs and 1 set of platnium p-lugs with no differance.
    SLAM.POKE.TUCK.DROP.DOPE!
    Townsvegas QLD
    Sorry i ended up on Jays comp some how
    Townsvegas QLD
    power is great but boost preasure has been raised ,so not sure what i should be expecting.
    Sep 2008
    Townsville
    Still havnt been able to sort this issue any more suggestions on what to look for .
    I reckon you need to monitor the fuelling as well Steve.
    Do you want to borrow my Innovate logger? Goes in the spare bung in the downpipe.
    Dec 2009
    West End, QLD
    Quote Originally Posted by kaneda View Post
    not necessarily so, so often ignition and fuel problems are misdiagnosed for eachother. ignition can do wierd unexplainable stuff.
