Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Running Cold
    Aug 2007
    Quote Originally Posted by marquee View Post
    So if I change my thermostat it should be fine
    Sent from my GT-I9100T using Tapatalk 2
    Totally no harm in doing so but i would recommend for your APK change the sensor too, like i say this engine is totally different regarding the stat as the OP. Your sensor might still be the problematic black one anyway, superseded with the green type. Fit both mate i reckon, for such a small item it can cause so much grief. Especially when it causes over fuelling, bore wash, over rich, bad starts etc. Its almost an item you would change every service if not every second. Back in the day the Transporter T4 service kit had a new temp sensor, this was in the Uk before any one gets confused
    Jmac
    Alba European
    Jan 2012
    Changed and still the same problem. Must be the thermostat
