Results 1 to 10 of 12
Thread: Running Cold
    Sep 2009
    Brisneyland, Queensland.
    Running Cold
    Evening all,
    I recently I noticed the temp wasn't coming up on the mrs mkiv. 1.6 5 speed. After driving for half an hour it was still on the bottom mark, ambient temp was about 20. Shortly after this it shot up to halfway which is where it normally sits. After another ten minutes or so I noticed it was back down on cold again. This has been happening consistently for a week now. It runs pretty rough when it starts in the morning. I've also noticed that the fans seem to be staying on for a while after you turn the ignition off. It has never done that, not even on really hot days. The engine bay seems remarkably cool even after a long run. Both fans appear to be working, feels like low speed but I can't be sure. Any ideas?
    Cheers,
    Sherwy.
    Aug 2007
    pm sent, to summarise for the masses itll be the electronic thermostat, it keeps the fan on and will be broken inside its housing. Common as .
    Jmac
    Alba European
    Apr 2012
    Peninsula, VIC
    Quote Originally Posted by Jmac View Post
    Jmac
    Tried to send you a PM Jmac but your inbox is full... can you please PM me the part that needs replacing??
    Is it this- Volkswagen Golf IV 1.8T > Engine > Cooling > Temperature Sensor > ES#2535452 Coolant Temperature Sensor With O-Ring & Clip - 059919501AKTU
    Ben
    Sep 2009
    Hey Ben,
    I doubt that is the correct part judging purely on price.... JMAC told me the part is $195 genuine. He keeps pretty close eye on this forum so I'm sure he'll get back to you soon. In any case I'm in touch with him about getting it fitted to my misses car so I'll let him know about your post.
    Cheers,
    Sherwy.
    Aug 2007
    Quote Originally Posted by ben_marrett View Post
    Ben
    No thats not it mate, the housings differ on the 1.6 some have a conventional thermostat and others have the electronic thermo. The one in question is a newer one with a BFQ motor, some of the early AKL and AEH motors have normal stats, but all use the coolant sensor you have in you link. As the BFQ motor has the electric one it throws the fans on full when it plays up and the engine runs really cool. What is your doing and what engine do you have?? by the way ill clean out my inbox tonight
    Jmac
    Alba European
    Apr 2012
    Peninsula, VIC
    Hey JMAC,
    Thought id post here so other have access to the info.
    Car:MK4 1.8NA(AGN)
    The problem is it struggles to get hot... if I leave it idle it gets hot but when driving in this melbourne weather the temp sits at about 1/4 and sometimes goes down to near zero. I have a new thermostat and will replace the current but want to make sure i replace anything else in the cooling system at the same time.
    Cheers,
    Ben
    Jan 2012
    Mine is exactly as described also. Just different engine. 2.0 apk
    Sent from my GT-I9100T using Tapatalk 2
    Aug 2007
    No harm changing your stat, like i mention above some of the housings are different, and especially the APK one like above. Depending what 1.6 you have it could just be the sensor in your link, but if a BFQ motor itll likely be the elec thermostat which comes with the sensor also so kills 2 birds with one stone.
    Jmac
    Alba European
    Apr 2012
    Peninsula, VIC
    Jmac
    No worries... will change the thermostat tomorrow and see the result.... if I still have troubles i will order the other sensor. Will post back results
    Ben (1.8 AGN)
    Jan 2012
    So if I change my thermostat it should be fine
