Results 1 to 10 of 11
Thread: rough gear changes
    Jul 2012
    gold coast
    rough gear changes
    I just replaced my dogbone mounts with polyurethane ones and now my gear changes are much more jerky. especially when changing down. I noticed the front bushing on the mount(the round one) is split. Would this be the cause? Should I replace it with a polyurethane one or will a normal one do? I also noticed one of the top mounts looked a bit worse for ware. Is their a good upgrade for these mounts?
    Cheers,
    Neil
    Quote Originally Posted by neilbarrett View Post
    Cheers,
    Neil
    I reckon if you give it a day or 2, you'll get used to the new set up and won't notice anything different.
    I have a race stiffness one on my S3 and don' have any problems.
    Jul 2012
    gold coast
    I changed it a month ago and it still doesn't feel right. Does this look like too much movement?
    MK4 Golf GTI Engine Mount Test - YouTube
    Aug 2011
    melbourne
    mine is a powerflex, i didnt notice anything except a tiny dash rattle which i promptly fixed.
    '02 GTI (clicky) - REFLEX SILVER - VIEZU race tune. VAR design 2.5inch stainless steel dump pipe with 100cell cat into 2.5" billyboat stainless cat back, Forge TIP, N75, Audi DV, ghetto CAI, FK-AK s coilovers, tunerdone LEDs, Clarion CZ301E sound stage.
    Jul 2012
    gold coast
    I dont get any rattle or vibrations what so ever.
    Apr 2013
    That video of you testing the mount kinda turned me on with all the thrusting and jerking...
    Jul 2010
    Canberra , ACT
    Hahahaha ^^ This guy !
    VW BORA 2003 V6 4Motion
    Volkswagen Golf MK3 1997 CL 1.8L
    Rammstien + Autobahn + Volkswagen = Leben !
    Apr 2008
    Cheers,
    Neil
    Any split bushings should be replaced.
    Stiffening the dogbone does remove flex between the gearbox and the chassis - so you will notice increased transmission of vibration, and it will feel a little more mechanical.
    Nothing to see here...
    Jul 2012
    gold coast
    Manaz.
    When changing down gears I can feel the whole engine/trasmision move which makes the whole car bounce! I thought the replacement dogbone inserts would lessen this not make it worse?
    Jul 2012
    gold coast
    Went to VW to get the front bushing in the dogbone mount turns out they can only replace the whole mount ( over $200!!!).
    Does any one know where to find replacement bushes that aren't poly?
    or any other solution?
