Results 1 to 10 of 12
Thread: rims specs for bora
    May 2009
    Canberra
    rims specs for bora
    hi there, just wondering if anyone knows what is the standard spec of the rim for bora pcd, ET? I'm looking at rs6, r32 rims or this rim.
    http://cgi.ebay.com.au/17-vw-rims_W0...d=p3286.c0.m14
    But i need to know the specs of the rim before i start shopping around.
    if any one can help me that would be great.
    cheers
    2009 Tiguan TDI and 2007 Passat TDI
    Feb 2007
    I think offset on std VW rims is between +38 to +42 (my std Sport alloys are +42), with the PCD being 5x100. By the looks of those rims, they'd prob be a 5x112 fitment (they look like a pretty late-model rim to me). I hope that helps mate.
    Mk3.Mk4.Mk1
    My Mk1 Project
    Apr 2008
    I believe that the standard 16" wheels are 16x6.5, ET38, and the standard 17" wheels are 17x7.5, ET38. All PCD 5x100.
    As madglf3 mentioned, I'm 99% sure the wheels in that eBay sale would be 5x112, so you'd need adapter plates to fit them (expensive, dubious legality, drastically changes the overall offset, pushing the wheels outwards).
    Nothing to see here...
    Nov 2008
    Sydney, Macquarie Park
    Quote Originally Posted by Manaz View Post
    standard 16" are 16x6.5 et42
    '01 VW Bora V6 4motion - gone
    17x8 TSW Hockenheims ~ TyrolSport Brake Upgrade ~ SMF + Stage 1 Clutch ~ 42DD Shifter Linkages ~ FK Coilovers
    Feb 2007
    My standard 16s are +42, but they are from my Golf (if that makes any difference).
    Mk3.Mk4.Mk1
    My Mk1 Project
    May 2009
    Canberra
    ris
    i'll give those rim a pass then. thanks for your help guys.
    May 2009
    Canberra
    rims
    Apr 2008
    I'm 99% sure those wheels would be 5x112 PCD (as they look to be a Mk5 rim), so no.
    You'd think a wheel/tyre merchant could put ALL the relevant detail into their ads, wouldn't you...
    Oct 2006
    those wheels won't fit a bora no.
    these will http://cgi.ebay.com.au/AUDI-18-WHEEL...lenotsupported
    http://cgi.ebay.com.au/ROTA-G-Force-...3286.m20.l1116 these will with spacers
    http://cgi.ebay.com.au/New-Racing-Ha...d=p3286.c0.m14
    they would be my ebay picks for a bora.
    if you want to go to a store instead, a lot better options.
    buy 18s, as 17s still look quite small on a bora/golf.
    May 2009
    Canberra
    rims
    "buy 18s, as 17s still look quite small on a bora/golf"
    I'm concern about felling the bump on the road if I put 18's coz I have to have a low profile tyre, and with the 17's I’ll still have a little bit better ride, by the time I’ve done my coil over. I hate hearing and felling or creating any rattle inside the car so I’ll try to avoid anything that will cause it if I can. I’m not being negative I do appreciate your help but I think I’ll stick with the 17’s but I will do some good homework if there is any solution if I end up with the 18’s. I love the audi rims but.
